İs HP X27i 2k monitor enough for gaming?
Solved by aisle9,
That is 100,000% dependent on what games you want to play and what resolution/settings/framerate you're looking for.
It's a 1440p 144Hz display, 27 inches diagonally, IPS panel and the price seems pretty reasonable. If that's what you're after, sure.
CosmicEmotion ·
Posted in Linux, macOS and Everything Not-Windows0 -
3
Bigchungusbutbigger ·
Posted in CPUs, Motherboards, and Memory7 -
Carroma ·
Posted in New Builds and Planning6 -
kasdashd ·
Posted in Folding@home, Boinc, and Coin Mining3 -
K2924 ·
Posted in General Discussion1 -
7
play_circle_filled
Latest From Linus Tech Tips:
Every Monitor Fails This Test… Except One - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
