CPU speed Stuck at 0.78
Go to solution Solved by unclewebb,
2 hours ago, Bharaj said:
ThrottleStop also didn't help
Open the ThrottleStop Limit Reasons window and you will likely see BD PROCHOT glowing red when you have this throttling problem. Clear the BD PROCHOT box on the main screen of ThrottleStop to solve this throttling problem.
Intel XTU incorrectly reports this type of throttling as thermal throttling. Uninstall XTU. It cannot be used to detect or solve a BD PROCHOT throttling problem.
Turn on the ThrottleStop Log File option before playing a game. Post some ThrottleStop screenshots and attach a log file while gaming to your next post if you are still having problems.
6700HQ
CPU speed stuck at 0.78 when play games, when unplug and plug power cord CPU start running fine but after 1 min will start throttling again
INTEL XUT shows thermal throttling but temps never go above 70°C any solution
I have tried Reinstalling windows didnt fix solution
ThrottelStop also didnt help
Thanks a lot, it's working fine again tested it in long gaming session and Multiple games everything fine 😁
it starts happening again
2022-08-23.txt
Is the BD PROCHOT box clear on the main ThrottleStop window? You always need to run ThrottleStop and the BD PROCHOT box always needs to be clear.
but its red and yellow when red come on then it faq up and cpu speed lower to 0.78
1 hour ago, Bharaj said:
red and yellow
Show me a picture of ThrottleStop with the Limit Reasons window open when your CPU is stuck at 0.78 GHz.
