XFX RX6600XT low fps and only max 50% usage
L4krs
Hi,
First my specs:
XFX Rx6600XT
Ryzen 5 3600
16gb 3000mhz dual channel Ram
Asus ROG Strix 750g 750W power supply
My problem is that when i play games my Gpu and Cpu dont go higher than 50% usage and my fps are much lower compared to other systems with the same specs
In valorant i only get 130-180 fps
In Apex max 140 fps
and even in Fortnite only 70 fps
every game on LOW settings still FHD. i tried reinstalling windows and getting the latest bios and drivers.
but nothing seems to fix it and now i dont know what else could be the problem.Could it be a cpu bottleneck or smth?
3 hours ago, L4krs said:
Hi,
First my specs:
XFX Rx6600XT
Ryzen 5 3600
In Apex max 140 fps
It's not your components, i get over 200fps (uncapped) in valorant with a 1600 and a 6600 at 1440p.  Do you have adaptive sync or vsync turned on?
I edit the shit out of my posts.  Refresh before you respond.
no all turned off
1 minute ago, L4krs said:
no all turned off
Temps?
15 minutes ago, Queen Chrysalis said:
Temps?
temps cpu and gpu both 50-60
OK so that's fine. Were you getting these framerates during, like, episode 3?  I haven't actually checked my framerate in a while, as I run with freesync at 75fps capped, so maybe episode 5 or the addition of pearl made the game more graphically intense.
IDK why fortnite would only be getting 70fps tho.
