Corsair SP120 fans x 6 -- Mobo chassis fan headers x 2 -- what to do?
Solved by Origami Cactus,
I had the corsair SP120 a long way ago, they use the same PWM as any other fan.
As far as the adaptor goes, idk what monstrosity you have chosen, Corsair SP120s are not server fans, they don't need 65w of power.
Get normal cheaper splitters, and you will be as fine as ever.
Something like this will work really fine, as the corsair SP120 fans use like max 0.2amp, and all modern motherboards have 1amp headers.
Even the LED version of SP120 only has 0.26Amp power draw, so 3 on the same header is fine.
