Asus Zephyrus M16 wont use gpu for external monitor.
Hellsmorky
I have a ASUS Zephyrus m16 with a rtx 3070, I recently bought a external monitor (AOC 27G2) that has a refresh rate of 144hz, but no matter what I do my laptop caps it at only 120hz because it says the display is using the intel integrated graphics. I've watched all the YouTube videos about NVidia control panel settings but it still wont change the display adapter and I cant find the option in my laptops bios to use only the graphics card. Can someone help me please?
Are you connected through usb-C to DP?
Is your laptop charged? My old laptop sometimes won't use the nvidia dGPU when not charged.
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI MSI PRO B760M-A WIFI DDR4
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
Is your laptop plugged in? I know mine won't even run the gpu if it's not plugged in as the standard battery doesn't allow for the proper power delivery to power gpus like a 3060 or 3070.
Also keep in mind that now display settings are more often than not done through windows display settings rather than nvidia control panel especially for laptops. I know my work laptop that has a nvidia quadro uses only the windows display settings and has the nvidia control panel mostly grayed out and unable to be changed there.
1st The RTX 3070 only activate when gaming and any apps use it. In Windows, it will run by the Intel GPU and this cannot be change.
2nd if you are connected via HDMI normally laptop came with HDMI and normally the HDMI version is not latest and it normally cap at 120hz or 60hz. Check the laptop manual.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, AOC 24G2SP 24" 1920x1080 165hz SDR, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods Pro, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile & Smart Watch: Apple iPhone 15 Pro Max (Natural Titanium), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
Unless your laptop has a mux internally to switch its output between the integrated and dedicated GPU, you're stuck with only the intel graphics for display outputs.
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
This is incorrect, I have an ROG laptop too, and if I connect an external display whether with HDMI or usb-C DP, it will be connected to the dGPU. Unless not charged.
CPU: Intel i5-12400
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
OS: Windows 11 Pro
Not every laptop can use Nvidia GeForce/AMD Radeon GPU as display output. It is very rare to have this function.
Majority laptop is design only can use iGPU from Intel or AMD as display output nor-matter you connect to power source or not.
Well, is his laptop in the majority of laptops? His laptop is an ROG Zephyrus, its the top of the line stuff, if my measly ROG Strix could have a mux switch, I don't see why his can't have it as well.
Also, you're generalizing a top of the line laptop with budget or average laptop that has no dGPU or low powered dGPU. Come on now.
CPU: Intel i5-12400
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
OS: Windows 11 Pro
I just notice all ROG series came with MUX Switch. You no need to reply such rude comment also.
The emboldened words provoked me, it wasn't uncalled for.
CPU: Intel i5-12400
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
OS: Windows 11 Pro
It is connected through a hdmi port and my laptop is plugged in when I use it with the external monitor.
I have a cable that is made for 144hz, and I know my laptop can handle 144hz because my monitor back home can run at 144hz.
what is a mux?
19 hours ago, Hellsmorky said:
what is a mux?
Is a device that allows the input to be redirected to either the integrated gpu or the dedicated one. As per the comments above, it seems like your laptop does have one, so I'm out of ideas here
Lenovo N23 Yoga
