question Asus RTX 2060 Dual EVO OC max fan speed on boot up
Solved by RONOTHAN##,
4 minutes ago, gunner_hero said:I'm just curious if it's normal that the fan speed is at the max on the boot up. But it goes to normal once it got to the windows.
Yeah that's pretty common. You'd probably need an engineer to give you the exact reasoning behind why they do that (I know a couple speculative reasonings like it helping to prevent the fans from stalling on start, but I don't want to say for certain), but basically every GPU I've owned has done that.
