Why does my clock speed just sit there at 1800? Precision X1 question
Solved by SimplyChunk,
Do you have 'Prefer Maximum Performance' selected in the power option of 3D setting in nVidia control panel? That'll usually do that. If you'd like a lower idle temp switch it to 'Optimal Power' instead
12345678 ·
Rummers ·
Posted in New Builds and Planning2 -
a7med ·
Posted in CPUs, Motherboards, and Memory1 -
5
1
moondogkill ·
Posted in Cooling1 -
1
snaphappy7530 ·
Posted in Troubleshooting4 -
JanS0lo ·
Posted in Troubleshooting3 -
3
play_circle_filled
Latest From Linus Tech Tips:
Every Monitor Fails This Test… Except One - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
