I'm Looking For a Case That Supports an ITX Motherboard and ATX PSU
I just learned today that I can't use my ssupd Meshlicious that I just bought for my build because my psu doesn't work sideways, I'm pretty beat up about it.
Does anyone know of a case that would support a upwards facing atx psu with a itx motherboard that's not too big?
Instead of buying another case, why don't you just buy an appropriate PSU?
Most actually small ITX cases use SFX power supplies. Otherwise you might as well just get a bigger case.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
I thought about it, but I'm having a hard time finding a sfx psu at a good price. I can only find 80+ gold psus that are quite expensive.
1 hour ago, Just_Landon said:
That psu looks like it's standing up
Silverstone’s RVZ line up might be what you’re looking for. Just note that I had issues with running really hot components in mine. 5800x and 6800xt was over temping the power supply.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
Don't worry to much about a gold, depending on the load the difference can be a few percent efficiency difference.
The important thing is its a known good PSU, although I'm not sure if we have any SFX charts for that.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
I had a Silverstone SG13, but that thing got hot. You'd need a 140mm AIO for your CPU too and crank that fan quite high, I'd just go with an SFX PSU even though it's expensive. Other cases I found are the Lian Li Q58, Jonsbo V10 and SG14, but IDK about the actual compatibility there.
Trans Rights!
Please tag me or use the "reply" function so I get a notification
I will find your Laptop thread and I will recommend an ITX build instead
Sure would be neat if there was something useful here, eh?
Fractal Design Node 304. Use a few at work, if I do an ITX build at home I'll likely use one provided the GPU fits (it will only fit 2-slot cards). 2x92mm fans front, 140mm rear, should fit up to an NH-D15/D15S, though I'd go for the NH-U12A to be safe.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
what's your budget?
and how long is your gpu
  • o11 air mini (on the bigger side)
  • sama im01 (it has a few name depending on region, tecware fusion in my region)
  • fractal pop mini air (fits matx too)
  • meshify 2 nano (does have some limitation compare to the mini)
  • torrent nano (comes with 180mm fan)
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
What psu do you have now?
  • 3 months later...
