I need help deciding on a motherboard for my build :)
Here is my build so far: https://ca.pcpartpicker.com/list/qzdjRv
I need to decide on a motherboard, here are the 2 contenders right now:
(1) Asus B660: https://ca.pcpartpicker.com/product/32NxFT/asus-prime-b660-plus-d4-atx-lga1700-motherboard-prime-b660-plus-d4
(2) Asus B660M: https://ca.pcpartpicker.com/product/yZPQzy/asus-prime-b660m-a-d4-micro-atx-lga1700-motherboard-prime-b660m-a-d4
I don't need to overclock, I need a few RGB headers for my case.
Which one is better out of these 2 MOBOs, and is it a good motherboard overall, and why?
I would love to see multiple different perspectives 🙂
They're pretty much the same board with the only thing being size difference, of course the matx will have slighly less connections so It mostly depends if you like the look of it.
It's an okay board, (I think you're going for a white theme?) So I'd get the b660 steel legend instead for 10 bucks more
https://ca.pcpartpicker.com/product/jRhFf7/asrock-b660-steel-legend-atx-lga1700-motherboard-b660-steel-legend
If not, I'd go for a msi pro b660 instead
This site is trash for budgeting a build. The 12600K price is way inaccurate. "359$" New Egg has them at 279$ for the K and the KF is 259$
Also, I want to suggest building a ddr5 platform if you want to compete with Ryzen 7000 and upgrade to 13th Gen.
My silly opinion of course. DDR5 isn't exactly cheap unless you can get by with a 2x8gb kit which is the route I went with.
It's canada?
Just now, Ryuikko said:
It's canada?
Oh, I see it IS Canada!! That explains the pricing. Thank you.
Doesn't the mATX one have more USB headers and more PCIe x16 Slots? Also I heard that Asrock boards aren't very good. It's more of a white / black theme, too lazy to get all parts in the same colour 😂. The reason I was going to go with an Asus board was because it has a bunch of RGB headers and has AuraSync for my RAM and case fans :).
Thanks you! I'm gonna look into the MSI one as well
I'm not stupid enough to be building this right now. I'm waiting for 13th gen and 40 series to come for price drops, as well as specific deals at the end of this year. No thanks... DDR5 is not something ima be getting anytime soon.
I would have appreciated you actually answering my question instead of ranting about PCpartpicker...
Yes, I'm sorry. I'm a human and already recognized that it was Canada PC part picker related and I didn't realize that until someone said something.
So again my apologies.
Everyone doesn't want DDr5, but they don't understand why, just whine about prices.
Since DDR4 is at end of life, 13th Gen will have a 20% uplift in performance using DDR5 over DDR4.
Educate yourself WHY you want to stick with DDR4, then appreciate your own choices later 😉
https://www.game-debate.com/news/31871/intel-13th-gen-cpus-could-get-a-20-performance-boost-using-ddr5-ram
Mhm matx boards have less internal connections then atx boards
Asrock is basically a roulette on if their boards are good or not. Their steel legend and taichi boards are great for their prices though
Afaik aura sync is software correct? So as long as the mobo recognizes it's connected go fans it (should?) Appear in its software
The msi board is probably the best one if you aren't going for a specific theme
 Share
