3070 Low Usage | Help!
Solved by Dukesilver27-,
Can't think of anything else other than resolution bottlenecked, because your CPU definitely could keep up with the GPU, and a lot of people with 3080s reporting the same issue.
You could try using Nvidia's DSR to render games at higher resolution, I've heard people suggesting people with 3080s to test with DSR, to check whether the resolution is the true bottleneck.
Try following this guide, https://nvidia.custhelp.com/app/answers/detail/a_id/3587/~/how-to-enable-dynamic-super-resolution-in-games.
