Recommendations for a 34" Curved Ultrawide Monitor for Work / Play
Parth Kharwar
I've looking for a 34" curved ultrawide in the $500-$700 price range primarily for work (a lot of coding, web development), media consumption (Netflix, Prime) and some light gaming (Valorant, Satisfactory).
The options I've considered so far in no particular order:
  1. Samsung CH890
  2. LG 34GP83A-B
  3. LG 34GN850-B
  4. Dell S3422DWG
I'll be running it off a Dell XPS 17, with an i7-12700H and RTX 3060 so I don't really expect high FPS while gaming. Would love to have USB C (with PD) on the monitor, but need a USB hub at minimum. Speakers would ofc be a bonus. I've come to the conclusion that at 34", 3440 x 1440 is the sweet spot for price to visuals range. And while IPS is definitely a better option, I might have to settle for VA here.
I'm looking at this a long term investment, which hopefully means an upgrade to a full tower PC, hence me spending so much time debating my options. Would love some help deciding or with new suggestions.
One of the LGs. Either one, really, I doubt you'll notice a difference between them unless you're using them side by side.
Welcome to the forum.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
LG 34GN850-B is a good solid monitor, was in my shortlist when I finally decided 18mo ago for an Alienware AW3420DW but both were in the $1,000 range at that time
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
I’ve used it for the past couple years and it’s an amazing monitor. I would note I am considering swapping to a Samsung 42” Qn90b 4K tv to get  more screen real estate for my work. The downside to an ultra wide is you can’t really comfortably use a second monitor with it. If I want the ultra wide experience I’ll switch it to the ultra wide mode on the tv.
Owned LG 34GN850 for 9 months, still love it. Had an VA but later went different layout with my room and slow response times became apparent. Swapped with nano IPS and still love it today.
Biggest problem was the price, because there's no alternatives apart from flat IPS or OLED, the price was triple of 27 inch 16:9 monitor. I also miss using PBP sometimes but it's not a big concern.
PC spec: CPU: RYZEN 9 5950X | GPU: SAPPHIRE NITRO+ SE AMD RADEON 6900XT (Undervolt to 1045mV) | MB: MSI MAG TOMAHAWK x570 RAM: G.SKILL TRIDENT Z NEO 32GB (2x16GB) DDR4-3600 (OC to 3800 14-15-15-25) COOLING: NOCTUA NH-D15, BE QUIET! SILENT WINGS 120 & 140mm| CASE: IN-WIN 707 | 5.25" BAY: LG WH16NS60 INTERNAL BLU-RAY OPTICAL DRIVE | PSU: SEASONIC PRIME PLATINUM 1000WUPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: CORSAIR SABRE PRO WIRELESS | CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS: LG 34GN8502x DELL S2721DGF | LG C1 48"
HT & audio stuff:  AVR: MARANTZ SR7013 | STEREO AMPLIFIER: YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II | MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
Do you think there's an issue with buying a monitor released a few years ago?
Any issues that you've faced with quality control or panel degradation? What would you say you've used it the most for?
Thank you! Would there be one of them that has an edge over the other?
Thank you for the response! What would you say your primary use case would be?
I do have a second 22" Dell that I run in vertical with my current 27" main. Could be a squeeze otherwise I'm happy to stick with just one for the clean aesthetic.
RTings liked #2 more. You can read the articles to see what is different between them, they're an excellent review site.
for those prices the 34gp83A-B would be my choice, never seen it that low before.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
I own LG 34GN850 and still love it. Now I put this monitor for working and never regret buying this. 😊
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, AOC 24G2SP 24" 1920x1080 165hz SDR, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods Pro, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile & Smart Watch: Apple iPhone 15 Pro Max (Natural Titanium), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
When I first bought LG 34GN850 from Amazon it had two noticeable dusts that were stuck inside screen and they looked like dead pixels. I swapped and this time no dust or dead pixels.
My monitor has some IPS glow on corners which I can tolerate, and there's a bit of red and green tint on left and right side of the screen when the whole screen is white. Reading around I seen people with LG 34GN850/34GP83-A having tinting issue as well but to me it isn't too noticeable.
I used the monitor mostly for browsing and games that doesn't support HDR.
It’s about the same price as I paid on Black Friday and it is still a good quality monitor. The biggest downside would be MINI LED or OLED will likely be available on most monitors in this price range in the next year or two.
A 27” under would be kind of unergonomic. I use my 13” laptop under while I do my accounting work. I use multiple windows at once to audit financials and it is convenient to have more things on screen at once for me.
