Where should I place my fans?
SKR25
I just bought the Fractal Meshify 2 Mini case to round out my PC build and wanted some opinions on how to do case fan placement.
My PCPartPicker list
I was debating between mounting the two 140mm fans on top or on the front. I can't decide between these two possible configurations and want some advice.
Top-mounted 140mm:
Intake:
69.17 × 3 = 207.51 CFM
Exhaust:
52.3 + (68.4 × 2) = 189.1 CFM
Front-mounted 140mm:
Intake:
(68.4 × 2) = 136.8 CFM
Exhaust:
69.17 × 3 = 207.5 CFM
For either config, I can purchase another fan and mount it as an intake on the bottom, provided I remove the 3.5" HDD cages (I don't plan on using them anyway)
Top-mounted 140mm:
Intake:
Exhaust:
Intake:
Exhaust:
I'd say the 1st option myself.  More cool air in.
Where do your numbers come from?  WHy do the 140's on top have more CFM per than the front, are you saying the 120's have more CFM than the 140's?  Did the manual outline this due to the mesh filters?
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Top-mounted 140mm:
Intake:
Exhaust:
Intake:
Exhaust:
Make sure you have neutral pressure (so as many fan in as fan outs) or positive pressure. Otherwise you have a dust collector on your hands
CPU Ryzen 5900X - Motherboard Asus ROG STRIX X570-E - RAM 16GB of G.SKILL NEON 3600 -
GPU EVGA RTX 3080 XC3 - Case Mastercase H500p mesh - PSU Seasonic Focus Gx-850 -
Corsair MP600 NVME 1 Tb, Samsung 960 PRO 500 Gb & 2 Seagate Baracuda 7200 RPM 2TB in stripe -
Display two VG27AQ 2K monitor - Cooling Corsair H150 Pro -
Keyboard G-910 W/ Romer G tactile - Mouse G 502 Hero (wired) -
Sound Logitech X-530 and Razer Tiamat headphones
Operating System Windows 10
I pulled those CFM numbers from PC Part Picker and they're subject to change based on air filters. Iirc, the front, top, and bottom of the case all have filters.
Sorry if it was unclear, but in both configurations, I was including the 120mm rear exhaust fan in all my exhaust calculations. That's why the 140mm top config had a higher CFM. It's the CFM of the two 140mm fans as well as the one 120mm rear exhaust, whereas the front-140mm config just uses the two front 140mm fans as intakes.
Essentially, all of the numbers are going to be lower in practice due to the mesh filters in the top, bottom, and front, since that would probably make a difference.
Can neutral pressure be achieved by just having an equal number of intakes vs exhausts, or do I have to try to equalize the CFM as much as possible?
IMO if yer look for CFM, 140 will be better
on radiator 120 typically has better static pressure
i would go with two 140mm front intake, two 120mm on both rear & top as exhaust
slight positive pressure is good for keeping dust out of gaps,
i test using incense sticks near panel gaps, if the smoke is not being pull into the pc then yer good
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
