monitor stuttering
Solved by Bombastinator,
33 minutes ago, Cerberrus27 said:I have had that on still same thing
Well that’s odd. So it’s not a synchronization issue unless for some reason they aren’t functioning. Rather extreme cpu or gpu slowdowns then. For cpu slowdowns one could check various administration bits to see if there is anything popping up and inturupting. I don’t know if there is the same for GPUs or not though.
