Bracket for the graphics card does it give anything?
Solved by Poinkachu,
26 minutes ago, GamerGry123 said:
I used one awhile ago, not that model though.
My GPU was long and heavy so the sag was so visible even on day 1.
if you plan to use one, I suggest getting a model with a wider base, the one you linked look like it will be kinda unstable.
Example #1 (One that looks a lot like the one I was using) :
Wider Base
Example #2 :
Scaleable Type
