Does the charger automatically select the power?
As long as the voltage is correct you're good to go. At the right voltage devices will only pull as much power as they were designed for, no fancy cables required. If it's specifically USB-C you don't even need to worry about the voltage, because the charger communicates with the device to select the right charging voltage. The worst case with USB-C is just that the device doesn't charge.
Fat Cat11997 ·
6
cbrngrz ·
Posted in Home Theater Equipment2 -
Brass5226 ·
Posted in LTTStore.com Merch1 -
1
sophietlav ·
Fat Cat11997 ·
Posted in Networking0 -
5
EzioWar ·
Posted in Graphics Cards3 -
2
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
