Please help me get chipset file for 12600K
Go to solution Solved by -rascal-,
That appears to BE latest Z690 chipset drivers (i.e. no patches / changes / updates).
It looks like Intel does not offer the chipset driver download directly.
Why are you looking for another (newer) chipset driver anyways?
Usually the patches / fixes are within the BIOS firmware updates.
That's why MSi has been rolling out a BIOS update for that board....basically on the monthly basis.
https://www.msi.com/Motherboard/MAG-Z690-TOMAHAWK-WIFI-DDR4/support#bios
As title says, msi driver is outdated by 9 months and everywhere on the intel website isnt a clear file to download. Where can I get the most dated file? Its not like the amd website where it gives u the latest chipset file clear as day on intel website the "inf chipset utility" doesnt have z690 listed on supported versions. Please help
8 minutes ago, CrossYT said:
No z690 tomahawk ddr4 and the file is 9 months old, no where on intel site does it have the file name and the most recent one
What do you need a driver for exactly? You don’t really need drivers these days for mobo’s. Is something not working correctly that is leading you to believe you need a chipset driver?
Rig: i7 10700k @ 5.1Ghz, 4.8 Ring - - Z490 Vision G - - EVGA RTX 2080 XC Ultra @ 2025Mhz - - 4x8GB Vengeance Pro 3000Mhz 15-17-17-34 @ 3500MHz 16-19-19-38 - - Samsung 950 Pro 512 NVMe Boot + Main Programs - - Samsung 830 Pro 256 RAID 0 Lightroom + Photo work - - WD Blue 1 TB SSD for Games - - Corsair RM850x - - Sound BlasterX EA-5 - - EK Supremacy Evo - - XT45 X-Flow 420 + UT60 280 rads - - EK Full Cover GPU Block - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 64 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - 10TB WD Red for expendable data - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone Xs - 2018 MacBook Air
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz (still tweaking) -- i7-6800K
  • Gigabyte Z390 Aorus Master -- ASUS X99 Deluxe
  • Sapphire NITRO+ RX 5700 XT Special Edition -- 2x Sapphire NITRO R9-Fury in Crossfire
  • 32GB G.Skill TridentZ DDR4-3000 CL14 (16GB TridentZ RGB + 16GB Red/Black TridentZ)
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO + 1TB Intel 660p NVMe
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Phanteks Enthoo Luxe Tempered Glass Edition
  • Ekwb Custom loop
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
Have they even been updated in the last 9 months? If there haven't been any issues then there would be no newer version, and that would explain why you can't find one.
You do, the OS just automatically installs them. Rest is correct though, you only need to search out specific drivers if you're having a specific issue fixed by it.
Main PC (tearing this down in a bit, 7980XE coming soon™) - i7 6950X - EVGA X99 Classified - 4x8GB 3200Mhz CL16 DDR4 - 2060 Super FE - 1TB 970 Evo/1TB MX500 - LG WH14NS40 BluRay Drive - EVGA 1000W G3 - Corsair Air 540 - Noctua iPPC NF-A14 3000 (rear) + 3x Noctua NF-P12 redux-1700 PWM (radiator) - LG 27UK650-W (27" 4K60hz) - Custom CPU/GPU Loop w/single 360mm rad - Windows 10
Project Rig (WIP) - Xeon I forgot the name of - NH-L12S - EVGA X99 Micro 2 - 4x4GB 2800MHz DDR4 - WX2100 2GB - 256GB 960 Evo - no PSU, currently in a Node 804
Daily Devices: 2015 15" MacBook Pro (Work Laptop) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: Mac Pro 1,1 (2x dual cores as I haven't swapped the quads in yet, 32GB DDR2 and a 512MB HD4870) running El Cap/Lion/sometimes other Mac OS X versions - iPod Video (5th gen)
 Share
