Searching hard for a Thermaltake F31 Suppressor Solid Panel.
Rivettz
I am digging deep to find a Thermaltake F31 Suppressor Solid Side Panel. If anyone has any leads. let me know. I will pay to have it shipped to me.
Marline
Top Loop:
Thermaltake Pacific PR2U Dual 5.25" Bay D5 Pump/Resorvior Combo / EK ZMT Tubing / A mixture of Chrome Plated Brass Rotary Fittings Bit Fenix and Alpha Cool / Alphacool NexXxos 280mm 45mm Thick Copper Pass-through Radiator / Alphacool NexXxos 140mm 45mm Thick Copper Radiator / XSPC G1/4 1/2ID Chrome Compression Fittings / Freeze Mod AM4 CPU Waterblock / 3x Noctua Redux 140mm fans
The Bottom:
Custom Made 2mm Thick Steel PSU Shroud / Aqua Computer Aqua Tube POM Reservoir / Alphacool Eisdeck 5 w/D5 655 Pump / EK ZMT Tubing / Alphacool 45° Chrome Plated Brass Rotary Fittings / Bitfenix 90° Chrome Plated Brass Rotary Fittings / Alphacool Chrome Plates Brass Pass Through Fittings / Koolance QD3 Quick Disconnects / Bitfenix Full Cover Water Block 2080ti / Alphacool NexXxos 200mm 45mm Thick Copper Radiator / Noctua Chromax 200mm Fan / The fluid I used for both was EK Cryofuel Acid Green
Computer Specs:
Thermaltake F31 Suppressor / Ryzen 9 3950X / 32gb G. Skill 3200mhz RAM / Asus B550-E motherboard / Zotac RTX 2080 ti 11gb / EVGA 1000 GS PSU / Samsung 970 Evo Gen3 NVMe SSD / Western Digital SN850X Gen 4 NVMe SSD / 4x PNY 120 gb SSDs in RAID 0 / 1x Spectre 512gb SSD / 1x Patriot 240gb SSD / 1x 1Tb Western Digital Black 7200RPM HDD / 1x 2Tb Seagate 5400RPM HDD / Windows 10
