Which Aio has the best quality parts?
Dear LTT Community,
(skip to “@question” for beginning)
I currently use a H115i elite capelix from Corsair to cool my CPU. It looks amazing and contributes to the aesthetics of my rig.
You might be familiar with the extraordinary loud pumps that are used in these coolers and how fragile they are. I didn't know this fact until the second replacement of the vendor.
Long story short I can't stand the high pitch noises that sound like an animal is da*ing inside my system.
That's why I have decided to sacrifice the looks of my system and use another noncorsair product.
The picture shows my current setup.
“@qeustion”
I'm looking for a reliable 280mm aio liquid cooler preferably pitch black no RGB. But you can recommend those anyways.
The rad shouldn't be thicker than 27mm as it otherwise would cover my RGB ram a bit too much. (Liquid Freezer ii is, therefore, no option)
- For the sake of completeness, you might consider mentioning the thicker aios anyways as this post should help anyone in search. -
The main concerns are noise, the quality of parts and software like icue, cam and what not.
Besides, I don't want it to cost more than 150€ (Germany).
Thanks for the responses
Kind regards
AlpacaRider
MSI has one that has the pump in the radiator, I would try that.
💌Your "Your "PC master race" thing is cringe." thing is really cringe.💌
19 minutes ago, AlpacaRider said:
Dear LTT Community,
“@qeustion”
Kind regards
AlpacaRider
EK’s system I would imagine is better. Or just get a good air cooler. They can look just as good. Keep RGB fans up top, and get a nice black air cooler from noctua. It’ll perform just as well and never make crazy pump noises.
Rig: i7 10700k @ 5.1Ghz, 4.8 Ring - - Z490 Vision G - - EVGA RTX 2080 XC Ultra @ 2025Mhz - - 4x8GB Vengeance Pro 3000Mhz 15-17-17-34 @ 3500MHz 16-19-19-38 - - Samsung 950 Pro 512 NVMe Boot + Main Programs - - Samsung 830 Pro 256 RAID 0 Lightroom + Photo work - - WD Blue 1 TB SSD for Games - - Corsair RM850x - - Sound BlasterX EA-5 - - EK Supremacy Evo - - XT45 X-Flow 420 + UT60 280 rads - - EK Full Cover GPU Block - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 64 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - 10TB WD Red for expendable data - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone Xs - 2018 MacBook Air
For quality parts I'd suggest EK and Alphacool, they make really good stuff, not like those big brands that put marketing and RGB puke above all 🙂
System : AMD R9 5900X / X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 (OCed to CL16)/ RTX3080 Gigabyte EAGLE GPU/ Phanteks P600S case / Customized Watercooling Eisbaer 280mm + Eiswolf2 360mm + VPP755 pump  and 150mm reservoir0.5TB Sabrent Rocket + 2TB WD SN850 NVme Gen4 + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/ 34" 120Hz 3440x1440p Alienware AW3420DW monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse
EK and Arctic make two of the best AIOs out there.
But they're somewhat "less shiny" than the RGB Heavy alternatives.
Keep in mind I didn't get to actually use it due to compatibility issues with my board, but I was incredibly impressed with the pump on the EK AIO I had. Even at full sauce that thing was super quiet, both as far as pump whine and liquid slosh. Certainly miles better than the pump in my Phanteks AIO (which is just a regular Asetek pump with almost zero sound dampening on the block).
Main rig on profile
Zephyrus - Windows 7 side rig
Intel Core i7 4820K, 1x8GB ADATA XPG V1.0 (1600MHz CL9), Asus Sabertooth X79, 240GB Kingston UV400, 1TB Toshiba 2.5", EVGA GTX 960 SC, Enthoo Pro, Corsair CX750M, Windows 7 Ultimate 64-bit
Mac Mini (Late 2014)
Intel Core i5 4278U, 8GB RAM, 250GB Samsung 840 EVO, macOS Monterey, Logitech G305 K/DA, Logitech MX Keys for Mac, ViewSonic VX2748 (last two shared with main PC)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X 1TB (technically retired now), Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 2TB, Nintendo Switch OLED
I found this clip featuring the EK Aio pump which does have a noticeable whine: https://youtu.be/FsHqEbuoh6s at 3.11
Currently, I consider these two but there is not one source that confirms that they are 100% good picks.
I'm still open to other recommendations.
I use the second one (Alphacool 280mm) and have no whine
I FOUND THIS RANDOMLY TODAY AND REMEMBERED YOUR POST. The pump is actually located in the hoses, it's wild and doesn't have rgb ANNNDDD pipe pump is supposed to help isolate the vibration and keep it quite! also it is exactly 27mm thick and right in your price point. ITS A PERFECT MATCH!
https://www.amazon.com/quiet-BW007-280mm-Cooling-System/dp/B08K3NHL5Q/?_encoding=UTF8&pd_rd_w=64nv8&content-id=amzn1.sym.8cf3b8ef-6a74-45dc-9f0d-6409eb523603&pf_rd_p=8cf3b8ef-6a74-45dc-9f0d-6409eb523603&pf_rd_r=P83JEGDQDE6KWDV1QH6X&pd_rd_wg=1r8zY&pd_rd_r=b0be3e2a-c736-4a9a-b4ea-a46882e71647&ref_=pd_gw_ci_mcx_mi
 Share
