Need advice on the SPECS for a Pre Built PC
Solved by TylerD321,
8 gb ram isn't enough for gaming. 256 m.2 nvme is fine for boot drive but only having 500 gb storage total is not ideal. If the 1660s is able to play the games you want, that should be fine. 1660s is just a little bit better than a 3050 for reference.
Pitboy64 ·
Posted in General Discussion2 -
ianm_ozzy ·
Posted in Servers, NAS, and Home Lab0 -
superbrett2000 ·
Posted in CPUs, Motherboards, and Memory8 -
BallinBonobo ·
Posted in Troubleshooting1 -
1
runningdecoy ·
4
joshp305 ·
Posted in New Builds and Planning2
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
