Need a workstation that will be crunching genome data
ynot563
Budget (including currency): $795.55 (weird price cuz subtracted cpu price from $1200) (This budget also includes tax and shipping)
Country: United States
Games, programs or workloads that it will be used for: Rstudio running genome data sequences and forming graphs with the data
Other details:
  • A friend have put this together in pcpartpicker if you need a starting point.
  • Existing part list - Already bought a new i7 12700k as well as have a old full size tower.
  • Motherboard needs to have onboard graphics and basic usb, mouse, keyboard, audio, and hdmi ports.
  • 1tb of hdd
  • Prefer fan cooler over AIO.
  • Do not need graphics card.
  • 32 gb ram or 64 gb if you can fit within budget
  • My current pc have done this process and was not built for this purpose, but it takes 9 hours. Specs are
    • cpu: Ryzen 5 3600 (6 cores)
    • ram: 16x2 gb ripjaw g.skill
    • motherboard: gigabyte b450m ds3h
    • graphics card: nividia geforce gtx 1660 super
    • power supply 850 watt
  • My biggest concern is the cooling for the i7 12700k. This workstation will be under 100% load for hours.
Thank you.
My understanding of post was you had a $1200 budget for this PC but you already bought CPU bringing it down to the $795 budget left. This is a build for around $720 and I put 128 GB of ram a little bit for the memes because I am not if that much ram will be useful. Really the big thing that I would recommended is getting the Noctua NH-D15 CPU fan if you are worried about thermals and make sure your case is decked out with fans. Do not use a case with a closed front, you will want a mesh front for airflow. You also don't need 4000 MHz ram, the 12700k caps at 3200 MHz stock. ( Intel® Core™ i7-12700K Processor )
https://pcpartpicker.com/list/zB7fxs
P.S> The CPU determines whether or not you need a graphics card, not the motherboard.
My PC Specs: (expand to view)
Main Gaming Machine
CPU: Intel Core i7-10700K - OC to 5 GHz All Cores
CPU Cooler: Corsair iCUE H115i RGB Pro XT (Front Mounted AIO)
Motherboard: Asus TUF GAMING Z490-PLUS (WI-FI)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600
Storage: Intel 665p 1 TB M.2-2280 NVME SSD (x2)
Video Card: Zotac RTX 3070 8 GB GAMING Twin Edge OC
Power Supply: Corsair RM850 850W
Case: Corsair 4000D Airflow
Case Fan 120mm: Noctua F12 PWM 54.97 CFM 120 mm (x1)
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x4)
Monitor Main: Asus VG278QR 27.0" 1920x1080 165 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
This should be good and even under budget
PCPartPicker Part List: https://pcpartpicker.com/list/2wZsVw
CPU: Intel Core i7-12700K 3.6 GHz 12-Core Processor  (Purchased For $0.00)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  ($64.98 @ Amazon)
Motherboard: MSI PRO Z690-A WIFI DDR4 ATX LGA1700 Motherboard  ($199.99 @ Amazon)
Memory: Corsair Vengeance LPX 64 GB (2 x 32 GB) DDR4-3200 CL16 Memory  ($199.99 @ Amazon)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive  ($109.99 @ Adorama)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ Corsair)
Power Supply: EVGA G5 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($59.99 @ EVGA)
Total: $729.93
Generated by PCPartPicker 2022-08-11 09:35 EDT-0400
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Given the load, a decent motherboard with good VRM and heatsinks is needed.
Invest in a new mesh front case with a clear airflow path.
Without a GPU, even a 550W PSU is more than needed.
An NVMe drive is not much more than an HDD and the performance improvement makes it well worthwhile.
Motherboard: Asus PRIME Z690-P D4 ATX LGA1700 Motherboard  ($204.99 @ Amazon)
Storage: TEAMGROUP MP33 PRO 1 TB M.2-2280 NVME Solid State Drive  ($74.99 @ Newegg)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: Corsair RMx (2021) 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($74.99 @ Newegg)
Total: $714.93
Generated by PCPartPicker 2022-08-11 13:49 EDT-0400
while motherboards no longer have onboard graphics these days, your CPU does have integrated graphics. Most motherboards will come with an HDMI and/or displayport output. So you don’t need to worry about that.
If you bought the KF version, it has no graphics and you will need a basic GPU; if that’s so and you’re in the US I have a GT610 I would send for cost of shipping.
This can be misleading. It’s true that’s the stock cap, but with XMP enabled it is easily capable of running FAR faster RAM. I’m using 32gb of Ballistix Max RGB DDR4-4000 (4x8gb because I got the first kit for a steal and upgraded it later on)
