O11 air mini or Fractal Torrent need help choosing
Go to solution Solved by jaslion,
42 minutes ago, em_lab said:
Hi recently i bougth a MSI Suprim X (34cm long) GPU. I going to change my Define R5 for another case due to airflow the poor airflow of this case.
Il would Ask for yours opinions about which one would be a better option for air cooling and câble management the 011 Air Mini or the Fractal Torrent?
Thanks in advance
The torrent is flat out the better one.
Plenty of cheaper cases that will also cool your system totlly fine
Thanks in advance
Changing the fans of the O11 for iPPC fans would help with airflow?
Personally I would go with the torrent, but it's mostly because of looks and I like the form factor better. Also should perform a little better.
CPU: i7 9700K@5ghz all core (silence + summer)
cache x47, AVX offset 0
Motherboard: Asus Maximus XI Hero
RAM: Patriot Viper Steel 2x8gb@3733mhz @jedec cl15
PSU: EVGA SuperNova 750 G3
Mon:  LG 27GL850-B, 144Hz Nano IPS - G-Sync compatible/Freesync
GPU: EVGA 1080ti SC Black Edition w/ G12 bracket
Sound: Odac + Fiio E09K
Case: Fractal Design R6 TG Blackout
Storage: MP510 960gb and 860 Evo 500gb
Cooling: CPU: Kraken X62 - GPU: Kraken X42(RIP) -> X53 (From RMA)
Thanks in advance
On thanks i prefer to keep m'y GPU thé must cool as possible si ill pick thé Torrent
 Share
