Need a recommendation for a mic and headphones (specific use case inside)
OrangePlayer
Hello my sweet Techtonians,
I'm looking to buy some wireless headphones and a microphone because my G930 Logitech headset is pretty beat. Although I was thinking about DYI trying to repair them, I'm a little bit concerned about messing around with a battery that is strapped to my head + I am unsure if I can find all the correct parts. But maybe I'm wrong and DYI is the way to go, let me know your thoughts.
But If I shouldn't DYI my old G930 then I need to replace it and for my replacement I have the following criteria:
  1. It should be wireless. I play long DnD session or game on discord and like to get up once in a while to move around, without missing anything.
  2. It should let me hear clearly what people say on discord or other similar programs (Skype, teams, zoom, etc)
  3. People should be able to clearly hear me
  4. It should have a USB plug  OR  3.5 mm jacks.
  5. A range of at least 60ft (~20m)
  6. And lastly the solution shouldn't be too hot. The G930 was pretty warm to wear in the summer.
Nice to have
  1. The ability to switch to cabled mod
Not important
  1. If it's an all in one solution or if mic and audio are separate
  2. If it's stylish
  3. If music sounds super good
  4. If I have "3D" sound while gaming
My budget is pretty flexible, I would probably be happiest if I got a deal for 80€ but depending on the feedback, could go to 200€.
Anyways I'm quaking in anticipation for your cool underground recommendations!
Look into Steelseries Headphones. A lot of their headphones are wireless but still have a 3.5mm jack. Only requirement of yours that they don't seem to meet is range. I think all of their headsets have a range of around 40 feet.
These headphones also have two volume knobs. One is master volume and the other adjusts the ratio at which you hear each channel. Typically I use mine at 70% on one channel (with discord on it) and the other channel at 30% (with games on it). A perfect 50/50 split makes the audio the same volume.
Gaming Headsets | Award-Winning Headphones | SteelSeries
My PC Specs: (expand to view)
Main Gaming Machine
CPU: Intel Core i7-10700K - OC to 5 GHz All Cores
CPU Cooler: Corsair iCUE H115i RGB Pro XT (Front Mounted AIO)
Motherboard: Asus TUF GAMING Z490-PLUS (WI-FI)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600
Storage: Intel 665p 1 TB M.2-2280 NVME SSD (x2)
Video Card: Zotac RTX 3070 8 GB GAMING Twin Edge OC
Power Supply: Corsair RM850 850W
Case: Corsair 4000D Airflow
Case Fan 120mm: Noctua F12 PWM 54.97 CFM 120 mm (x1)
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x4)
Monitor Main: Asus VG278QR 27.0" 1920x1080 165 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
@TylerD321
Thank you very much for the feedback!
I will take a look at the Steelseries. They volume knob thing sounds like a great feature for my use case!
They're called Arctic, does the name represent? Do you find them comfortable and cool?
2 hours ago, OrangePlayer said:
@TylerD321
They have two different earmuffs, the leather can be a little warm but the default is great.
Main Gaming Machine
