How to fix no sound when I plug in headset?
Solved by noonie94,
On 8/10/2022 at 10:33 AM, TylerD321 said:Did you select the correct audio device? Which windows do you use? On Windows 10 you can click on the sound icon by your clock, then there is a carrot (^) you can click on to choose where sound is playing to.
update:
Update: So NZXT cases have this problem (I looked on google), instead of going through the hassle of getting a replacement of the same case, I just returned it to amazon and went to Best Buy and got the Corsiar 4000d airflow which is a nicer case and have better airflow. In my personal opinion the NZXT h510 is a nice looking minimalistic case, but it Thermals sucks and so does the hd audio plug. If anyone else experience this problem contact NZXT or just do what I did and buy a different case.
