Looking for a good usb c to 3.5mm (or quarter inch) and charging adapter
MysticDragon
Looking for a good usb c to 3.5mm (or quarter inch) and charging adapter, the one I currently have is horrid.
No quick charging features, crackles when I ride my bicycle, randomly stops when riding my bicycle, etc.
Was just curious if anyone here had any recommendations for a quality one, I am guessing if I both want to charge my phone and plug my headphones in any actual audiophile options are out the window, but I am no expert in this field hence why I thought i'd ask here.
Thanks in advance.
Have heard the name xumee before, ranks well on Amazon.
USB Type C to 3.5mm Headphone and Charger Adapter,Xumee 2-in-1 USB C to Aux Audio Jack Hi-Res DAC and Fast Charging Dongle Cable Compatible with Pixel 4 3 XL, Galaxy S22 S21 S20 S20+ Note 20 (Grey) https://a.co/d/bM8o7nN
Looks basically the same as I have now but with a brand on it, not sure if it actually will be better
Thanks though, i'll look into it
If you want to forgo charging, I hear a lot of good thing's about the apple dongle
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
Don't use a apple device and don't wish to support apple, but thanks ^^
Might be worth finding out if your USB-C port provides analog audio (Audio Accessory Mode) however to sure if you can use this mode at the same time as charging your phone... thaknyou USB standard group for adding yet another optional spec to the list...
Well… Apple typeC-to-3.5mm is small cheap and does what it needs to do… and probably your best option… but sure don’t support a good product
I'm sure it will only half work on a android device, that's how apple tends to do it 😉
It does not
Not really, there is no 'half work' - it is an adapter that 'just' works (unless your port is 'charge only' for whatever reason). I have no idea what you do mean by 'apple tends to do it', elaborate.
Apple airtags are a good example, made to work just on apple devices
Yes but no. 'Made to work only with...' is a thing. There is no 'kinda works' or 'half works'. It is an accessory made for a specific device - no confusion there.
While an adapter as such is not 'made for Apple', it just an adapter.
Do you also look at Apple Pen or a Lightning cable and wonder why they don't work on non-Apple devices?
Do not put different things into the same bucket.
1 minute ago, rikitikitavi said:
Yes. 'Made to work only with...' is a thing. There is no 'kinda works' or 'half works'. It is an accessory made for specific device - no confusion there.
Shrug. Decent points, I suppose.
Either way, rather have something that also works with charging
