Gigabyte RTX 3060 Ti power indicator flashing while playing games
ahmedbatty
Go to solution Solved by DoctorNick,
2 minutes ago, ahmedbatty said:
Light flashes, but I haven't experienced any crashes ever.
Would I be having any problems down the line? or should I just stay with this power supply?
Hard to say. Too bad you dont have a CX650, which has 2 seperate cables. You'll know if you've tripped the PSU. PC will crash. You could try pushing GPU harder to see if you can get it to crash. Personally I would change the PSU, especially if you plan to upgrade CPU and motherboard at some point.
Summary:
I recently got a Gigabyte GeForce RTX 3060 Ti and the power indicator is flashing on one of the sockets.
What I Have:
PSU has 2x 6+2 pin cable for graphics card.
Graphics Card has 8 pin and 6pin power sockets.
I have named A and B for referencing throughout this post. (as shown in pictures)
What's Happening:
While playing games the power indicator light above connector B blinks, which according to the Gigabyte graphics card website means 'any power supply abnormality'. (You can check Video1, Video2)
I still went ahead and checked a few things:
  • Checked the snugness of the cables. Shut down the computer, turned off the power supply, removed the cables from the card and inserted them again checking if its fitting right. [light still blinking]
  • Swapped the power connectors. Connected 8 pins of B and 6 pins of A. [light now blinks above the 8 pin]
I have tested the following games:
  • Watch Dogs 2
  • Red Dead Redemption 2
  • Hot Wheels Unleashed
  • Batman: Arkham Knight
  • The Witcher 3
  • Fallout 4
What could be the problem?
  • Is 650W less for my PC?
  • Is the power supply faulty? (I have been using this PSU since early 2019, used with an ROG STRIX 1060 on the same PC)
  • Is there anything else I should check? Do let me know.
Edited by ahmedbatty
Added list of games tested for this issue
Tried using 2 separate PCIe cables instead of daisy chain yet ?
Refresh before you reply
Ok so the lights flash? Does it work without crashing? If yes I would suspect voltage spikes. RTX 3000 series is known for this. (this is normal)
Thank you for posting a thread with such great detail and information! (this is rare)
I wouldn't worry too much as long as the PC runs stable.
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
PSU only has one cable with 2x 6+2
Edit: But yes a fix could be to get a PSU which has 2x2 6+2 PCI-e cables such as RM750 or RM850 @ahmedbatty
FS in Denmark/EU:
Yes, PSU only has one cable. I wish there were more so I could have used 2 different cables.
Yep, sorry, didn't really notice that when I posted a reply. Was too focused on the pics.
If the system runs things stable I doubt it's faulty PSU.
I'm not an expert, but maybe the card detected a big enough voltage drop on the daisy chain & think it's something gone really wrong.
No problem man, thank you for your reply
Sounds like bad connector/cable.  Probably too much resistance, so you're getting a voltage drop the card doesn't like.
I'd stop using it since there's actually a potential fire hazard there.
You could try a SATA to PCIe adapter.
Um... I advise not.
SATA connector is rated for max 54 watt, PCIe connector is 150 watt.
Unless we really know for sure how many watt the port that we attach the adapter into pulls, it's not a safe thing to do.
Especially with RTX 30 occasional power spikes.
But I do agree with checking the pins inside the connector, just in case.
FS in Denmark/EU:
1 minute ago, Poinkachu said:
Um... I advise not.
6 pin is 75W, and the adapters are 2 SATA connectors to PCIe.
Actually I do plan to upgrade the CPU, motherboard and RAM later this year.
I could change the power supply in the next month or so. Could go for something like a 80 Plus Gold semi-modular or modular.
How would I go about this?
Would I require a multimeter?
Do you have any good articles or videos to direct me to?
Yes RM750/850 is a good choice
FS in Denmark/EU:
