What to change for better performance or min max etc
Budget (including currency):  5000 usd
Country: americuhhh
Games, programs or workloads that it will be used for: video game rendering and random generation
https://pcpartpicker.com/list/RJ9DQ6
My PC Currently Is The P2-1320a.
private list
  • CPU
    I7 12700KF
  • Motherboard
    MSI Tomahawk z690 WIFI DDR4
  • RAM
    16gb Vengeance Pro
  • GPU
    RTX 3070 TI
  • Case
    NZXT H700i
  • Storage
    crucial P2 500gb m.2
    Raid 0 16tb server
  • PSU
    Corsair RM1000X
  • Display(s)
    ASUS PG259QN 360hz
    ASUS PG278QE 165hz
  • Cooling
    NZXT KRAKEN X62
  • Keyboard
    Corsair K95P Brown
    Ducky one 2 SF Silver
  • Mouse
    Razer Viper Ultimate
    logitech pro superlight x
  • Sound
    DT 990 PRO
Also alternate suggestions for making it cheaper but keeping the baseline high performance would be nice aswell as price increase while increasing performances etc.
I'd also do water cooling but sounds too complicated and idk what to buy so will just stick with fans and radiators
way too much money being dumped wrong here,
you're pairing all these strong parts into a b chipset motherboard instead of a mainstream x570,
you could use an hdd server,
you're buying a full price windows key,
1600w is overkill,
can't talk about ram count for rendering and such but would make an educated guess,
you might be fine with 64gb instead of 128.
  • CPU
    I7 12700KF
  • Motherboard
  • RAM
    16gb Vengeance Pro
  • GPU
    RTX 3070 TI
  • Case
    NZXT H700i
  • Storage
    Raid 0 16tb server
  • PSU
    Corsair RM1000X
  • Display(s)
    ASUS PG259QN 360hz
    ASUS PG278QE 165hz
  • Cooling
    NZXT KRAKEN X62
  • Keyboard
    Corsair K95P Brown
  • Mouse
  • Sound
    DT 990 PRO
1600w is overkill,
you could aso benefit more from a 360mm cooler, you're cheaping out on the wrong parts here.
  • CPU
    I7 12700KF
  • Motherboard
  • RAM
    16gb Vengeance Pro
  • GPU
    RTX 3070 TI
  • Case
    NZXT H700i
  • Storage
    Raid 0 16tb server
  • PSU
    Corsair RM1000X
  • Display(s)
    ASUS PG259QN 360hz
    ASUS PG278QE 165hz
  • Cooling
    NZXT KRAKEN X62
  • Keyboard
    Corsair K95P Brown
  • Mouse
  • Sound
    DT 990 PRO
From what I can see, you pretty much built the top of the line PC. The only improvement you can do CPU wise is getting an EPYC.
What I would do to save some money is buy a Win 10 Pro Key from a website, they are like dirt cheap. I don't think giving 100$ to Microsoft for the Home version is worth it imo.
Here is what I've done - https://pcpartpicker.com/list/drFDQ6
Went with non rgb ram, but you can change it if you really want RGB. 2x32GB should be fine and if you see that you need more, just buy another set.
need motherboard w thunderbolt
1600w is overkill,
motherboard recommendations? pref thunderbolt w bluetooth and wifi
When your budget is this high why not wait a few weeks for new Ryzen generation?
Desktop: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - RMx 750 W 80+ Gold - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro Corsair K70 LUX browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
what new ryzen generation
Ryzen 7000, AM5. Should be announced end of August with reviews around mid September and release at end of September.
