"default radeon wattman settings have been restored due to unexpected system failure" after setting custom fan curve + -10% power limit.
Solved by BiotechBen,
10 hours ago, WarsawWarrior said:Just didn’t need the extra power so thought it’d be a way to reduce heat
That may be causing instability. Would recommend reducing clocks instead.
Vibes NoVibes ·
Posted in Troubleshooting0 -
5
kim921 ·
Posted in Build Logs1 -
Dalynx ·
Posted in Storage Devices0 -
Fat Cat11997 ·
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
