Search In
  • More options...
Find results that contain...
Find results in...
Is it better for a PC to have amd gpu and cpu or does it not matter?
 Share
Doesn't matter. What specific cards are you thinking about getting?
PSU Tier List | SSD Tier List | GPU Hierarchy
Mark my answer as solution if it answered your question :). Quote or tag me so I get notified of your reply.
My PC:
CPU: i5-10400F | GPU: Powercolor RX 6600 Fighter 8gb | SSD: Crucial MX500 500gb | HDD: Seagate Barracuda 2tb | PSU: Corsair RM650x (2018) | Motherboard: ASRock B460M Pro4 | Case: Antec DP301M
My peripherals:
Monitor: AOC C24G2U & Samsung SR35 | Headset: Steelseries Arctis 3 | Keyboard: Drevo Seer Max (Gateron Brown) | Mouse: Logitech G703 | Mousepad: Steelseries QCK Edge XL
At the current moment amd cards have much better price to performance, you can get a 6900 xt for the retail of a 3080 which 3080s are still 50-100 dollars above retail, you can also get a 6750 xt for around the same cost as a 3060/3060 ti whereas the 6750xt is higher performance than the 3070 but if you want stuff such as better raytracing then go nvidia rtx
It doesn't matter. Just get what's better for your budget.
New Build (2022 - Present): AMD Ryzen 9 5900X | Nvidia RTX 3080 Ti FE | G.Skill Trident Z Neo 32GB DDR4-3600 | ASUS Crosshair VIII Dark Hero | 2x Samsung 970 Evo Plus 2TB | Crucial MX500 1TB | Corsair RM1000x | Lian Li O11 Dynamic | LG 48" C1
Cooling: Optimus Foundation AM4 | Alphacool Eisblock 3080 FE | EK Quantum Kinetic TBE 200 w/ D5 | HWLabs GTX360 and GTS360 | Bitspower True Brass Enhanced Multilink 14mm | Corsair 14mm White Acrylic | Mayhems XT-1 Nuke Clear | BeQuiet Silent Wings 3 120mm PWM High Speed fans
Deus Ex (2015 - 2022): Intel Core-i7 4790k | ASUS GTX 980 Strix | Corsair 32GB DDR3-2400 | ASUS Z97 Deluxe | Crucial M550 512GB | 2x WD Black 3TB | Corsair AX750 | Lian Li O11 Dynamic | LG 32GK650F-B
Cooling: Corsair XC7 | EK GTX 980 Strix Fullcover block | XSPC EX240 x2 | EK Quantum Kinetic TBE 200 w/ D5 | Monsoon 3/8" ID 5/8" OD Gold Compressions | Primochill 3/8" ID 5/8" OD Primoflex Advance LRT Elegant White Tubing | Mayhems X1 Clear | Corsair SP120mm fans
 Share
