Where do i put my front usb connector on my mobo?
Solved by DoctorNick,
5 minutes ago, ShiroEerie said:In my motherboard i have a usb 914 and usb 1011, can i put it anyone of this?
Its a Asus B360m K
Yes. They are the same: Here the overview of the mobo. From manual. Look at the number info about each port. You can see the info on page 1-2 port: https://dlcdnets.asus.com/pub/ASUS/mb/LGA1151/PRIME_B360M-K/E13808_PRIME_B360M-K_UM_WEB.PDF
