5800x3d temps high
Go to solution Solved by PDifolco,
6 minutes ago, 4PcBuilder said:
That cooler was not made for a cpu this power ful that’s my it’s in the mid 80s but you don’t really need to upgrade to 360mm aio that should be fine and if he rlly wants to he can get a 240 or 280mm aio but 360 is unnecessary
5800X3D PPT is 105W, not that much compared to 5950X or Intel 12900 that reach 200 to 250W+, so the Fuma2 could handle it, it's 6 pipes double tower 2 fans!
Problem is not power, it's the chip design, same as the 5800X, with 8 cores on 1 die so heat is very "concentrated" and not in the center. Plus according to reddit the 3D cache makes things worse and even ppl with 280mm AIO report 80 to 85C temps under CBR23, so I don't think upgrading the cooler will make much
Idk much about Scythe fans tho, maybe swapping them for Noctuas would improve the situation
My friend just got a 5800x3d.
Runs a scythe fuma 2 for cpu cooler and a p600s for case.
We are playing tarkov and his temps are creeping up to 81c
He ran occt variable extreme all core stress and it hit 86c.
Idle temps are around 44-55c.
It was just installed and pasted with noctua nt h1.
Are these normal temps?
I know it runs hot but does he need to consider getting a 360aio?
Depends also on your fans and how is setup your P600S, if you have all vents closed it doesn't have good airflow
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
I don't think it will thermal throttle until 90C or above so I wouldn't necessarily be too concerned.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
Sounds pretty normal to me.
That's with Corsair iCUE H150i Capellix, a 360 AIO
Refresh before you reply
It’s not the best cooler for the cpu. 6mm heat pipes be struggling to tame that beast.
AMD R7 5800X3D | Thermalright Aqua Elite 360, 3x TL- C12 Pro, 2x TL-K12, SYY-157
Asus Crosshair VIII Dark Hero | 4 x 8GB G.Skill Trident Z Mix @ 3733 14-14-14-34 1.5v
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X, 2x SN770, Asus Hyper M.2
EVGA SuperNova 750w | Fractal Torrent Compact | 1x Phanteks T30, 1x TL-B12, 1x TY-143
Yup. Make sure the case is setup in the airflow mode (remove the front panel on the mesh).
TJ max for that chip is 90C. It will throttle itself to protect itself, so you aren't going to do any damage.
The Fuma 2 can be a bit weak in my experience. It has great price to performance, and noise normalized performance, but the low fan speed can be limiting in demanding situations. A 360 AIO is not the only option and may not be worth the added complexity. There are some damn decent air coolers out there, and maybe even just replacing the fans on the Fuma 2 could be a good option.
BabyBlu (Primary):
  • CPU: Intel Core i9 9900K @ up to 5.3GHz, 5.0GHz all-core, delidded
  • Motherboard: Asus Maximus XI Hero
  • RAM: G.Skill Trident Z RGB 4x8GB DDR4-3200 @ 4000MHz 16-18-18-34
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2070MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 10 Pro
Roxanne (Wife Build):
  • CPU: Intel Core i7 4790K @ up to 5.0GHz, 4.8Ghz all-core, relidded w/ LM
  • Motherboard: Asus Z97A
  • RAM: G.Skill Sniper 4x8GB DDR3-2400 @ 10-12-12-24
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Corsair Vengeance C70, w/ Custom Side-Panel Window
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair AX760
  • Display: Samsung C27JG56 27" 2560x1440 144Hz Freesync
  • Cooling: Corsair H115i RGB
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
It might not be the best cooler you can buy, but it is more than enough for this cpu.
The cooler is perfectly fine for this cpu.
I can tell by the high temps that it is perfect.
Those are normal temps for this chip, and not cause for concern.
You can't apply the same standards for what good temps are to every CPU.
Ty for the info everyone.
Seems like this is pretty normal.
I had him clean out his filters and apply a more aggressive fan curve.
Now I understand why they didn't go higher than 8cores with x3d
Those temps are normal for you maybe.. I know of a couple of guys who have one and they don’t run as warm. I recommended my cooler to one of them, went from loads in the 90s to loading at 80. 10-12c is a big difference..
But it is summer, and people are really into high performing, quiet systems.. the trade off for ultra quiet is ultra warm 🙂
There is nothing wrong with 81c.
So 80c is fine, but somehow 81c is concerning ?
Weren’t you just talking over 85 not long ago? So if you saw 85 during some stress, chances are you saw 90 too.
Run it any way you want, it’s not mine lol..
What are you talking about ? The op states 81c in his opening post. Not sure where you are getting 85c or 90c from.
Well then..
You aren't looking very hard. Its right there, 4th line of the OP.
86c OCCT, he probably stopped it before it went higher.
Edit:
OCCT isn't that stressful at the setting he was running, so chances are if he ran something heavier like Linpack Xtreme, he would for sure be hitting limits of some kind.
30 minutes ago, freeagent said:
Well then..
Edit:
A stress test isn't everyday usage though is it ?
Also any stress test that extreme will cause issues for most coolers. If you look at any review for the Fuma 2/Rev.B you will see it is highly regarded. I know Gamers Nexus gave it a good review.
We also haven't established the op's setup i.e If they are running with the front panel on or what the fan setup is etc.
Depends who you ask 😄
There are work loads that are similar. If you just a gamer then no, probably not. But games aren’t stressful yet he was in the 80s just playing a game..
Maybe, it would depend more on your clock speed, and caseflow setup. It might be highly regarded, but it’s no where near the top. Especially with higher TDP chips.
Maybe if you are into overclocking then sure 🙂
Nope it isn't near the top, but it is designed to be a quiet cooler rather than raw performance, so the fan speed isn't as aggressive as some other coolers.
