512 PC fan not detected - HP
Solved by johnt,
1 minute ago, Antiquated said:I just got the same error again even though i checked the connections a few weeks ago .
Try unplugging the fan and start the computer to see if you continue having the same error message. Don't worry about your temperatures... you won't hurt anything by disabling a chassis fan. Turn your machine off again and then plug the fan back in and start up. See what happens. If you still get the error, that might just be HP quality. If it's only an error message and it's not causing any usage issues, you might just need to ignore it.
