Help my pc won’t boot
Solved by killswitch6000,
check the power supply cables and see if all of them are connected properly. something similar happened to me and i realised that the cables were lose on the PSU end. If the red light isnt coming on then its probable that the board doesnt have power. so when u were doing the additional wiring, u may have loosened the cable on the PSU side. if all is fine there, check the 24 pin header on the motherboard side.
