Search In
  • More options...
Find results that contain...
Find results in...
What is ring and would it be worth overclocking it
Go to solution Solved by RONOTHAN##,
9 minutes ago, SircarrotII said:
What is ring
It controls the cache and the interconnect between the cores, similar to the infinity fabric on AMD but it behaves a bit different.
10 minutes ago, SircarrotII said:
would it be worth overclocking it?
Yeah, it can give some pretty big performance differences in some workloads, but it can be a bit annoying to stress test.
What is ring and would it be worth overclocking it?
What is ring
 Share
