Rtx 3070TI or rtx 3060TI or rtx 3060
Solved by MrMase,
From the choices you outlined my preference would be the RTX 3070 TI as it gives you the most additional capability.
Part of this comes from the games intended to be streamed now and in the future but also the complexity of your stream setup, for example I found that if using a number of high resolution resources scaled down for the OBS (or other) streaming software would add excess load on the GPU.
In my case I resolved that by scaling down the resources depends on what you use.
