Search In
  • More options...
Find results that contain...
Find results in...
Using separate PSU to connect dvd drive sata power
 Share
Hi everyone,
My dad has found some old DVD's of his marriage ceremony and he wants to retrieve data from them. Currently my PC doesn't have any spare sata power connectors/DVD drive. So can a spare PSU be used to power a LG DVD drive while a sata data cable is connected to the main PC? My PC specs is in my signature. So will it be fine as sata data doesn't conduct voltage and only has data in+out and 3 GND pins.
The old PSU is a CX430 from 5yrs back.
  • Ryzen 5 3500
  • Asrock x570 Phantom Gaming 4
  • G.Skill TridentZ RGB 3600Mhz 16gb
  • MSI Mech 2X RX6600
  • Benq Mobiuz EX2510
  • Deepcool Castle 240EX A-RGB
  • Lian Li Lancool 215 Mesh
  • Kingston A2000 250gb + Wd Blue 1tb HDD, Sn550 1tb + Bx500 480gb
  • Antec EAG Pro 750 80+G
11 minutes ago, R2G_RR94 said:
Hi everyone,
What @BiotechBen said above.
or just buy a cheap sata power splitter, or molex to sata adapter.
Refresh before you reply
Hi everyone,
Yes it’ll be fine, as said above you need to jump the PSU tho. Maybe… just unplug a harddrive while you rip the DVD? Make it much easier.
Rig: i7 10700k @ 5.1Ghz, 4.8 Ring - - Z490 Vision G - - EVGA RTX 2080 XC Ultra @ 2025Mhz - - 4x8GB Vengeance Pro 3000Mhz 15-17-17-34 @ 3500MHz 16-19-19-38 - - Samsung 950 Pro 512 NVMe Boot + Main Programs - - Samsung 830 Pro 256 RAID 0 Lightroom + Photo work - - WD Blue 1 TB SSD for Games - - Corsair RM850x - - Sound BlasterX EA-5 - - EK Supremacy Evo - - XT45 X-Flow 420 + UT60 280 rads - - EK Full Cover GPU Block - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 64 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - 10TB WD Red for expendable data - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone Xs - 2018 MacBook Air
It'll probably work but I wouldn't really recommend it for anything other than a one off situation... Like @LIGISTX suggested it will be better to just unplug another SATA device instead.
If you're planning on using DVDs more often in the future I would recommend picking up a USB external DVD drive. They're reasonably cheap at about $15-$20.
49 minutes ago, BiotechBen said:
You'd need to use a jumper to get the secondary PSU to power on.
Its just for a onetime use as this is just available on the dvd and no digital copies are present.
Just needed a quick something to do it as getting a usb powered one would be the wise decision but it would take much time to come as they are not readily available here.
Anyways I connected it and copied everything and it worked fine.
  • Ryzen 5 3500
 Share
