Search In
  • More options...
Find results that contain...
Find results in...
Freesync not working properly
 Share
As the title says, my freesync isn't working properly on my 24GM79G-B 144hz monitor. It makes the screen flicker or make the game tear even worse with it enabled. List of things i've tried to solve the issue:
Reinstalling drivers multiple times
Disabling fullscreen optimizations
Limiting my fps manually with RivaTuner to 141
Limiting my fps in game
I'm using the displayport cable that came with the monitor.
It's been an issue from day 1.
I'm using the RX 590 GPU with R5 2600 CPU
R5 2600 (stock cooler)
RX 590
G.SKILL 16 GB 3000mhz RAM
MSI B450M GAMING PLUS
APACER SSD SATA3 500GB
DEEPCOOL MATREXX 55 (not the mesh version)
x5 ARCTIC P12 PWM
What settings are enabled (enhanced sync, v-sync, etc.) in Radeon software, and what did you limit your fps to with RivaTuner? And what GPU are you using?
Primary Gaming Rig:
AMD Ryzen 5 5600 3.6 GHz 6-Core CPU, Gigabyte B450 I AORUS PRO WIFI mITX AM4 Motherboard, PNY XLR8 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory, Mushkin PILOT 500 GB NVME SSD (boot), Corsair Force Series 3 480GB 2.5" Solid State Drive, XFX Radeon RX 5700 8 GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold Fully Modular SFX PSU, Windows 10 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
AMD Ryzen 7 3700X 3.6 GHz 8-Core CPU, ASRock B450M Pro4 mATX AM4 Motherboard, ADATA XPG GAMMIX D20 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory, Mushkin PILOT 1TB NVME SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD, PowerColor Radeon RX VEGA 56 8 GB GPU, Fractal Design Node 804 MicroATX Mid Tower Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray/DVD/CD Writer, Windows 10 Pro, Logitech K400 Plus Wireless Mini Keyboard w/ Touchpad, Corsair K63 Lapboard Combo (MX Red w/Blue LED) Wireless Gaming Keyboard, Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
 Share
