MSI GF 75Thin display issue
Solved by da na,
Welcome to the forums!
Sounds like a damaged/disconnected display cable, that was shaken loose by the fall. Could be on the screen side or motherboard side. If there's no visible damage to the screen, I'd take it to a professional and tell them the internal display cable has issues (unless you want to repair it yourself, but if you're new to laptops that's a decently difficult repair.)
Littellittel ·
Posted in Troubleshooting0 -
ShadowBroker50 ·
BANGINGxBT ·
Posted in Graphics Cards3 -
eliasboss3 ·
Posted in Storage Devices6 -
arachi9 ·
Posted in CPUs, Motherboards, and Memory2 -
10
1
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
