Pc weird chainsaw noise.
Solved by Poinkachu,
14 minutes ago, Maximefort said:It's the fan
In q-fan control when i change the speed of the fan it starts that annoying sound
Should i get a new fan for cpu?
Yea, we knew it.
Monitor your temp, and see how high.
You can replace it with aftermarket CPU cooler, but if you don't add atleast an intake fan. I doubt the situation will change much
it will be quieter when you idle due to bigger heastsink, but when you start hammering the CPU or GPU with heavier task, the CPU & GPU fans will start ramping up immediately
Without an intake & exhaust fan, at most your CPU cooler will keep recirculating the hot air the GPU, CPU, HDD, SSD, NVME, Motherboard expeled
