P500A Case Fan/Strip RGB issues with Gigabyte Z690 Mobo
Solved by GreatLament,
Found a solution thanks to a user on Reddit!
It turns out I needed the system powered on and the RGB Fusion software open. Then I plugged the M/B D-RGB 3-pin cable from the case into one of my mobo's ARGB headers and the case RGB was finally controlled by RGB Fusion! I had to make sure to Calibrate it within the software because the colors were mixed up at first, but I eventually got it working. Except for two of the Sync color settings that didn't seem to be compatible with the case RGB.
After all this effort, I just went back to using the stock P500A RGB modes anyway. They look really cool.
