Search In
  • More options...
Find results that contain...
Find results in...
Gigabyte B660M DS3H vs MSI PRO B660M- B vs MSI PRO B660M-G
Go to solution Solved by lee32uk,
9 hours ago, PDifolco said:
I think the MSI PRO B660M- B is better than the M, more slots and better VRM
And MSI B660 PRO boards have been ranked generally better than the Gigabyte DS3H
The B660-A and B660M-A are the only good ones from that lineup. The B660M-B and B660M-G listed above are both equally terrible. The Gigabyte board has an actual VRM heatsink so that would get my money out of the three.
Im wondering which one is best? its only gonna be used for an i5 12400f, their all rougly around 135-140 USD, i was looking for the A version but its a whopping 190 USD, these prices are translated from my curency, im mostl ikely never gonna use more than 1 GPU,
cheers.
System : AMD R9 5900X / X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 (OCed to CL16)/ RTX3080 Gigabyte EAGLE GPU/ Phanteks P600S case / Customized Watercooling Eisbaer 280mm + Eiswolf2 360mm + VPP755 pump  and 150mm reservoir0.5TB Sabrent Rocket + 2TB WD SN850 NVme Gen4 + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/ 34" 120Hz 3440x1440p Alienware AW3420DW monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse
Winter is Coming.
cheers.
How much is the Gigabyte B660 Gaming X (mATX or ATX version) ?
The Gigabyte B660M DS3H would be my choice otherwise.
Winter is Coming.
Indeed I've confused the B and A version, which is the good one
Its almost 200 USD lmfao
 Share
