Dell Optiplex 7090 Audio Problem
Solved by mudflapman,
Only other suggestion, apparently the Dell Optimizer software can work in place of the Waves Audio software. Perhaps that's worth a shot.
Didn't want to link to the drivers directly, but should be easy enough to come through on the product page below. Dell Command Update might be a good option to grab the lot and patch everything, but it's up to the end user to make that call (I personally don't mind it, but others will probably consider it bloatware, same as the audio apps I guess) :)
https://www.dell.com/support/home/en-au/product-support/product/optiplex-7090-desktop/drivers
