Exhaust fan making clipping sound
Solved by Sarra,
So, do you have onboard graphics?
You might need to reinstall your R9 270, go in to Windows in Safe Mode, DDU your drivers, then shut down, put your 960 back in, and try again. You might need to go into your BIOS and disable onboard graphics.
IhateAMDDRIVERS ·
Posted in Troubleshooting1 -
SashaSanguine ·
Posted in General Discussion6 -
6
Redsin ·
Posted in Graphics Cards3 -
BTSHalfLifeAndGmodFan2003 ·
Posted in Graphics Cards12 -
1
3
1
3
2
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
