Search In
  • More options...
Find results that contain...
Find results in...
I need help about aerocool cs 108
bal723
 Share
Go to solution Solved by JKRsega,
Cool. Can you mark my post as the answer please.
I saw photos on offiical website, but I didnt saw any photo with ventilation system, if someone has it or any information how the ventilation works, please send me pictures of it.
To be honest, you'll need something with a mesh front to get any decent airflow.  That looks like something to cook components in.
Its the only cheap and long mini tower case for my 296 cm 980 ti
I can also take cs 105 but it would have hard drive in top part of caae
You'll need to find one with a mesh front or leave the side off.
What about cs 107 v2
I will have to cut 1 cm in front only
I have the cs 105 sat in a cupboard.  Get a mid tower case.
hell nah its will be bigger then 40 cm in height
CS 107 V2 is MUCH better.  It can actually get air in the case.
but my 980 ti won't fit in because of max 286 mm limit
You need a bigger case mate!
no no no!
Why no to a bigger case?
I got no place on a table, and also here's some cheap mid it towers:
aerocool quantum
aerocool saturn frgb
aerocool bionic
Easily fit GPU.  I have 1660 super. Could fit two of them!
I kNOw
Send me a link to your site.
 Share
