Pc no power and no fan spinning
Solved by Poinkachu,
23 minutes ago, Maximefort said:Did i've done something wrong?
Without actually knowing exactly what you did step by step, we don't know.
Have you re-checked the PSU switch?
Try replugging the cables.
Re-check the front panel connector, maybe you plug them wrong.
Try powering on by shorting the power pins using a screwdriver, maybe the power on button on the case busted.
All those above good and fine ?
Try doing a PSU test.
Either simply by using your old motherboard & cpu
or by doing the paperclip test (Unplug all cables from your PC parts first, just in case)
