motherboard I accidently scraped my motherboard and bent the “solid capacitor” next to it the pin with the cap on top of it
Solved by Needfuldoer,
We'd need a tighter, more in-focus shot of this area to diagnose anything over the Internet:
Check those traces very carefully to see if they're broken or shorted together. If you're lucky, you just took the solder mask (paint) off and can cover it back up with some kind of lacquer or enamel. (You can buy little bottles of solder resist, but drugstore nail polish is basically the same thing.)
