air pressure
Solved by RONOTHAN##,
The biggest disadvantage with negative pressure is that it tends to gather more dust than positive pressure. If you're prepared to clean your system regularly it's fine.
Onions ·
Posted in Linux, macOS and Everything Not-Windows0 -
1
SyndiShanX ·
Posted in Audio7 -
Nexxus ·
Posted in Programs, Apps and Websites3 -
ds5018 ·
Posted in Troubleshooting5 -
5
Muzzy2002 ·
Posted in New Builds and Planning4 -
modern_officer ·
Posted in Laptops and Pre-Built Systems6 -
5
Coding2bLazy ·
Posted in Troubleshooting9
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
