GPU Temps
r1cky-
Yeah a bit, a 2060 shouldn't hit 80C... I had a 2060S it was on full load 70-75C max
you may have
  • old thermal paste, a 2060 could be 3 years old, time to repaste
  • dust on the GPU, disassemble and clean it
  • fans running too low (use afterburner to set a curve) - supposing they do work at all
  • or just a general heat problem on your case (GPU choking against somehing, badly vented case..)
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Your GPU hot spot temp is high,it shouldn't be 20 degree celsius higher than the GPU.
Like @PDifolco said, you should try to replace thermal paste first,if it's still high then maybe the fan of the GPU was stuck or running too low, increase its fan speed could solve the problem but it could be noisier.
