Advice for overclocking 2070 super
6 minutes ago, ragnarokkr said:Do i push it too far ? It is stable (been playing on it for a few day now) and i know OC will always reduce the livespan on a card but, should i tone it down a bit ?
Too much voltage is what reduces the lifespan of a GPU, on a GPU without locked voltage control like the 20 series there's not really any damage that comes from OC. I'd just run those settings, maybe increasing the power limits a bit more as that can help keep core clocks higher overall.
11 minutes ago, ragnarokkr said:Why sometimes MemCLock skyrock to 8000Mhz for 0.2 sc and then goes back to it's normal state
GPU boost is weird. It spins up to do something 3D (I.E. opening the start menu).
14 minutes ago, ragnarokkr said:It usually peak around 75/77°C, is it too much ? or is it good enough (i'm guessing it's ok since the fans don't turn up more than 67/70% but idk)
77C is safe. Lower is better and everything, usually the lower temps you can have the higher frequencies you can run, but I wouldn't worry about it.
