Should i go for i5 12400f or ryzen 5 5600x
Solved by ColdFusion04,
According to Gigabyte's CPU compatibility list (https://www.gigabyte.com/Support/CPU-Support) it is compatible.
If the board would be only for f-versions, it wouldn't have HDMI/DP-ports in the first place, the only mayor difference between i5-12400 and i5-12400f is the missing iGPU on the f.
The 12400 is a tad more expensive though (RCP $192 vs. $167)
