Can someone help me with this issue?
AdytzusanUwU
Hello
I recently reinstalled my Windows and this issue appeared out of nowhere
I don't know... the ui or the images with the text disappears a appears...
Are all of your graphic's drivers up to date? whether that be integrated or discrete?
Could also be that your pc needs to be updated in general, if you didn't connect your pc to a network while installing windows, it could have a whole mess of updates to install
Graphics drivers yes, all up to date... all done by NVIDIA GeForce Experience, Iv let it done all for me
The thing is... after I re-installed the windows, all worked smoothly, only after I started installing all the drivers for GPU,CPU and motherboard.... the problem came back (thing is I didn't reinstall my windows only because this problem, because I had it before... I reinstalled it because I wanted to update my windows to the newest version, from 20H2 to 21H2)
This is a bit of a long shot, but.
Try uninstalling your graphic driver using DDU
Then reinstall it manually (not from/by using GeForce Experience)
Refresh before you reply
Man, you really helped me, now everything works normally aaaand.... didn't know about this DDU till now, this is amazing, thanks ^_^
